Activity Forums Web Design (WordPress, Joomla, etc.) pop up windows and XP SP2
  • pop up windows and XP SP2
    Posted by Mgondek on April 23, 2005 at 3:50 am
    I have website with small icons of product shots, and when the user clicks on the small icons I need a bigger image at 370 pixels to come up in a window which uses only 370 pixels.
    No problem with the basic javascript, except SP2 blocks the windows adn even turned off the pop up blocker is going nuts.
    Below is the code I am using
    function MM_openBrWindow(theURL,winName,features) { //v2.0
    window.open(theURL,winName,features);
    ====================or===========================
    function dpSmartLink(u,n,w,h,p) { // v1.4 by David Powers
    var a,j,k,x,y,f=”;if(!n){n=”;}if(w){f+=’width=’+w+’,’;}if(h){f+=’height=’+h+’,’;}
    if(p){p=p.split(‘:’);if(p[0]!=’z’){p[0]==’c’?(x=(screen.width-w)/2):x=p[0];f+=’left=’+x+’,’;}
    if(p[1]!=’z’){if(p[0]==’c’){y=(screen.height-h-p[1])/2;if(navigator.appName.indexOf(‘Op’)!=-1){
    y-=96;y=y<0?0:y;}}else{y=p[1];}f+='top='+y+',';}}a=arguments.length;if(a>5){for (k=5;k
    Mgondek replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
