Activity Forums Apple Motion Pop up book simulation
  • Pop up book simulation
    Posted by Frank Stearns on March 9, 2011 at 9:31 pm
    Hi, Does anyone know how to create a pop-up book simulation in Motion 4? I can only find tutorials on how to do this in After Effects. Thanks!
    Frank Stearns replied 15 years, 6 months ago 2 Members · 2 Replies
  • Stephen Smith
    March 9, 2011 at 11:44 pm
    How you do it in AE should be very similar to how you do it in Motion. In a nutshell you just need to get your “book” broken into layers so each item can pop up out of the book. Before you animate each pop up item adjust its anchor point to say the bottom of the object if you want to adjust its rotation so it appears as if it is flat on the book and then rotates up. Its all about where you move the anchor point. Because it defaults to the center. Hope this helps and best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Frank Stearns
    March 10, 2011 at 7:24 pm
    Thanks, Stephen. This does help me think about how I could make the pop up!
