Activity › Forums › Adobe After Effects › Poor quality Tff/PSD in After Effects
  • Poor quality Tff/PSD in After Effects
    Posted by Ryab Smith on January 11, 2012 at 4:15 pm
    I’m bringing in a file that is 2000×1000 into after effects, originally it was a tiff, but I separated the car from the BG and changed the format from CMYK, to RGB, and saved it as a PSD.
    I bring it into after effects, and it is fine when I preview it from the project window, but when I bring it into a comp it looks like it’s about 25 percent resolution.
    Any thoughts
    Kevin Camp replied 14 years, 8 months ago 3 Members · 3 Replies
  • Erik Waluska
    January 11, 2012 at 4:51 pm
    At the bottom of the composition window, check that the resolution is set to “full” and the size is set to 100%.
  • Ryab Smith
    January 11, 2012 at 5:04 pm
    For some reason it renders out fine to full resolution but, its pixelated when I am working on it. And it is set to %100.
  • Kevin Camp
    January 11, 2012 at 5:19 pm
    there is a quality switch in the switches panel of the timeline (a check box that looks like a diagonal line). make sure that is set to ‘best’ (it should look like a smooth diagonal line).
    also, if you have opengl enabled for previews (preferences>previews) uncheck the opengl acceleration option.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
