Activity › Forums › Adobe Premiere Pro › Poor quality of video exported from Premiere Pro
  • Poor quality of video exported from Premiere Pro
    Posted by Per Olsson on February 19, 2017 at 3:47 pm
    Im getting poor quality when exporting an image sequence with .png files. I tried increasing the bitrate but with no success.
    As you can see on the uploaded footage the image are getting blurred and not crispy.
    I also attached my settings
    Howcome this outcome? What can i do to get full quality?
    videofile sample:
    11052_forum.mp4.zip
    settings:
    11053_namnlost.jpg.zip
    Per Olsson replied 9 years, 7 months ago 2 Members · 10 Replies
  • 10 Replies
  • Tero Ahlfors
    February 19, 2017 at 4:49 pm
    Well the sample doesn’t help because I have no idea how it should look. Post a frame from the original sequence.
  • Per Olsson
    February 19, 2017 at 4:57 pm
    heres a sample image. as you can see the video is blurred
    sample image:
    11054_0481.png.zip
  • Tero Ahlfors
    February 19, 2017 at 5:19 pm
    You have an insane amount of noise stuff happening in the clip and that is pretty much uncompressable. The codec can’t retain the information you have happening on the screen.
  • Per Olsson
    February 19, 2017 at 5:22 pm
    okey. guess I just have to put the bitrate all the way up 🙂
  • Tero Ahlfors
    February 19, 2017 at 6:08 pm
    Bitrate probably won’t help because your shot is too complex. It has to compress something. An uncompressed/visually lossless codec would but I don’t know where you want to use this animation.
  • Per Olsson
    February 19, 2017 at 6:16 pm
    its for installation.
    what codec would you suggest?
  • Tero Ahlfors
    February 19, 2017 at 6:51 pm
    What kind of playback system does the installation have?
  • Per Olsson
    February 19, 2017 at 7:17 pm
    depends. but most of the time through laptop to projector
  • Tero Ahlfors
    February 19, 2017 at 8:16 pm
    DNxHD or Prores. Both can be played back on Windows and Mac but Prores can be only exported on a Mac.
  • Per Olsson
    February 19, 2017 at 9:16 pm
    Prores did it!
    Thanks a lot!
