Activity Forums Maxon Cinema 4D Polys disappear when connect and delete
  • Polys disappear when connect and delete
    Posted by Eddy Elliott on May 23, 2017 at 11:01 am
    Hi all,
    When I try the connect and delete command on several polygonal objects they just disappear.
    It connects just fine on some but not on others.
    Am I missing something?
    Thanks in advance.
    Eddy Elliott replied 9 years, 3 months ago 1 Member · 1 Reply
  • Eddy Elliott
    May 23, 2017 at 1:40 pm
    Ahhh, ok, for anyone else likely to encounter this problem, the solution was to turn off the Viewport Solo Switch on the left hand panel.
    All the best.
    Eddy
