Activity › Forums › Maxon Cinema 4D › Polygon count
  • Polygon count
    Posted by Jason Stirret on June 11, 2011 at 10:15 pm
    Is there a polygon counter within C4D? One more question…have an object with mucho polygons, how can I reduce the count (poly reduction) without loosing the objects form? I have tried polygon reduction, and yes its works to a point, but you reach a threshold where it starts to warp and randomize the original shape. Is there another method or am I to suffice with poly reduction?
    Thanks allot!
    Randy Johnson replied 15 years, 3 months ago 2 Members · 1 Reply
  • Randy Johnson
    June 12, 2011 at 9:44 am
    Right Click on the object in the Object Manager and click on OBJECT information that is your poly count.
    As for reduction I generally do it by hand welding and moving points…. or in more cases than not I remodel using the first as a guide.
    As for using the poly reduction you can current state object command and start over sometime you get a little closer but I cannot really say its worth the effort.
    /Randy
