Activity Forums Maxon Cinema 4D Poly selections to object state
  • Poly selections to object state
    Posted by Jcoursey on October 31, 2006 at 9:45 pm
    Hi Cow.
    I am fairly new to C4D…but I am having the hardest time figuring out how to take a poly selection and make it an object so I can animate the various parts.
    Please see image here for an example of what I am trying to do: https://movies.fatbox.com/JC/Mozaik.jpg
    What is the easiest way to take each letter of the word Mozaik and make each letter it’s own individual object.
    I should note, this model was an imported model from Lightwave.
    Thanks in advance.
    Jason
    Jcoursey replied 19 years, 10 months ago 2 Members · 2 Replies
  • Brian Jones
    October 31, 2006 at 11:29 pm
    -select the polys of the letter you want to separate
    -use the Split command (Structure or Functions)
    -makes a new object with a copy of the selected polys
    (original polys are still there make invis or delete…)
  • Jcoursey
    November 1, 2006 at 12:13 am
    You da man, Brian!
    Thanks so much.
