Activity › Forums › Apple Final Cut Pro Legacy › Poll – how to make a “trippy” or “druggie” POV experience with filters?
  • Poll – how to make a “trippy” or “druggie” POV experience with filters?
    Posted by Keith Mann on June 26, 2007 at 12:48 am
    I need to turn party walk-through shots into the POV perspective of different recreational drugs.
    So anyone got some “trippy” suggestions for either fcp filters or FX’s?
    Thanks in advance…
    (PS – please do not feel it is necessary to do “research” on this.)
    Steve Eisen replied 19 years, 3 months ago 9 Members · 10 Replies
  • 10 Replies
  • David Roth weiss
    June 26, 2007 at 1:24 am
    There are several kaleidoscope plugins – they always seems to work well for a drugged-out POV.
    “No job is worth doing more than once…”
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • David Roth weiss
    June 26, 2007 at 1:51 am
    See the “borders” plugin, looks druggie to me
    https://www.chv-plugins.com/silkandfog.html
    David Roth Weiss
    Los Angeles
  • Shiloh Heyman
    June 26, 2007 at 3:31 am
    Light rays and Trails are 2 to check out
    Shiloh
  • Bret Williams
    June 26, 2007 at 4:49 am
    Check out the bad TV filter. Separating the color channels gives that feel. Otherwise blurs, glows, etc.
  • Steve Wargo
    June 26, 2007 at 6:38 am
    Drop a couple hits of Orange Sunshine or maybe a tab of Purple Microdot and then walk through a party so you’ll know if anybory is giving you the correct advice.
    Hint: You’ll need trails and smearing. And pitch up the audio a touch. Enough for it to bother your central nervous system.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut Pro systems
    Sony HVR-M25 HDV deck
  • Shane Ross
    June 26, 2007 at 6:45 am
    [Steve Wargo] “Hint: You’ll need trails and smearing. And pitch up the audio a touch. Enough for it to bother your central nervous system.”
    I see those when I go without water for 2 hours while wearing a TUX and posing for the 500th wedding photo in Phoenix…in July.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Tom Meegan
    June 26, 2007 at 12:20 pm
    Composite filtered video over itself without filters, ie:
    Layer one, video unfiltered
    Layer two, same video filtered.
    Composite mode on layer two. Experiment with different composite modes to get an effect you like. Also, adjust the opacity on layer two to control the strength of the effect.
    Another thought, apply smoothcam and then play with the Mix parameter.
    Tom
  • Chris Poisson
    June 26, 2007 at 12:55 pm
    That’s hilarious Steve!
    Yes, trails and smears should help a lot. Also, if you have AE, CC Time Blend does some really weird things. Also Turbulent Displace.
  • Keith Mann
    June 26, 2007 at 2:12 pm
    Great suggestions.
    Can anyone suggest how to do smears and trails as I’ve never done them before in fcp.
    Thanks in advance,
  • Steve Eisen
    June 27, 2007 at 2:56 am
    CHV-Time Collection Filter Set!
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
