Activity Forums Adobe After Effects Pointing to an object in a 3D precomp
  • Pointing to an object in a 3D precomp
    Posted by Pierpaolo Ferlaino on March 26, 2015 at 9:46 am
    I’m not sure it can be done and I hope I ‘m clear about what I’m trying to do.
    Basically, when I distribute objects in 3D space, in order to point the camera to a specific object I do like this:
    – link the camera to a 3D null
    – copy the position of the target layer
    – paste it to the position of the 3D null
    Now the camera is pointing at my target object…
    Can I do the same thing if these object are inside a precomp with collapse transformation on?
    I have a pre comp with my objects distributed in 3D space and I need to use different instances of this precomp but I would like my camera to point exactly at a some layers inside this precomp…
    I know I can do this by hand but I was looking for a more precise method… If it even exists…
    Pierpaolo Ferlaino replied 11 years, 5 months ago 2 Members · 2 Replies
  • Cassius Marques
    March 26, 2015 at 1:16 pm
    I’m assuming you want to get the current position of a layer to keyframe a camera animation. The simplest way would be to keyframe and animate your camera inside this precomp, then copy/paste the camera to the parent comp and compensate its transformations for any space/time discrepancies.
    You can also use expressions that access and translate any space coordinates of any layer inside any comp to any other comp. (e.g creating a null and “linking it” to the layer you need to address, so you can copy/paste as you’re used to.)
  • Pierpaolo Ferlaino
    April 3, 2015 at 9:56 am
    Yes. That is what I was trying to do…
    Many thanks…
