Activity › Forums › Adobe Illustrator › Point Type Scaled for Area Type
  • Point Type Scaled for Area Type
    Posted by Kian Mckellar on April 1, 2012 at 5:11 pm
    I often create area type and then wish to scale it similar to what I do with point type. Instead it just adjusts the area which the text can be within. Is there anyway to free transform an area type box? I feel that sometimes I’ve gotten this to work but I have no idea how. Thanks in advance.
    Kian Mckellar replied 14 years, 5 months ago 3 Members · 4 Replies
  • Vincent Rosati
    April 1, 2012 at 7:43 pm
    Select the text box than click S (Scale tool). Then it will resize the box and the text that is inside it.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Kian Mckellar
    April 2, 2012 at 2:35 pm
    Thanks. Been searching for that shortcut for a while.
  • David Cabestany
    April 4, 2012 at 4:08 pm
    You can also use the transform tool for that.
    I also often create a quick shape right next to the text box, a square or something like it, I select both together and scale down to what I need, then I delete the square.
    I know it sounds like too much a hassle, but I’m so used to it that I do it probably faster than using the scale tool.
  • Kian Mckellar
    April 18, 2012 at 2:35 pm
    Hmmm, interesting. I’ll have to try that.
