Activity › Forums › Adobe After Effects Expressions › Point on the surface of a sphere (rotating)
  • Dan Ebberts
    June 21, 2011 at 5:04 pm
    How about just putting a null at the center of the sphere, parenting your layer to that, then rotate the null (or wiggle its rotation properties) however you want?
    Dan
  • Robert Morris
    June 21, 2011 at 5:10 pm
    That’s EXACTLY what I’ve been playing with now. I had thought I wouldn’t be able to get the global position value of the null if I did that, but thanks to another of your expressions:
    L = thisComp.layer(“Null 1”);
    L.toWorld(L.anchorPoint)
    …I was able to! Now I’m just creating a set of sliders so I can adjust the value of the radius and various properties.
    I thought there might be a way to just do all of this without parenting, only using expressions. But parenting a null to a “Center” null with rotation definitely seems to give me the control I wanted. It doesn’t quite move in a gyroscope-ish way, but that might be a matter of me tweaking the values more. Thank you for your help!
    Fine Art Drawings | Photography | Compositing | VFX | Titles | Keying | 3D
