Activity Forums Maxon Cinema 4D POINT Edit w/Deformer
  • POINT Edit w/Deformer
    Posted by Glenn Takakjian on February 28, 2006 at 1:00 pm
    Is there any way to edit a polygon’s points while the object is being effected by a deformer?
    I have an object being bent by a deformer. While it is in the bent shape I want to adjust some points… (FOR PLA Animation)
    However, it seems as long as the deformer is active I can’t even select points much less manipulate them with magnet or brush tool. I have to un-deform it and guess as to how much I need to manipulate the points… deform it… see if its right … undeform… tweak.. etc etc. The deformer is animating as well so I can’t just do a Current state of Object.
    I seem to recall some sort of preference that allows you to work within the deformed mode… maybe its just wishful thinking.
    TAK
    v.9.1
    Mac OSX 4.4.5
    Brian Jones replied 20 years, 6 months ago 2 Members · 11 Replies
  • 11 Replies
  • Brian Jones
    March 1, 2006 at 5:28 am
    [Tak West] “Is there any way to edit a polygon’s points while the object is being effected by a deformer?”
    Yes, in the Windows menu not the main menu, go to Edit/Configure or Mode/View Settings in the Attribute manager and check off Deformed Editing
  • Glenn Takakjian
    March 1, 2006 at 8:50 am
    Thanks Brian… this is in fact what I was looking for… However I think I was not as clear in my question as I should have been.
    What I want to be able to do is “Select” points or polygons while an object is being deformed. And then use the move tool or scale tool.
    For some reason this does not work even with deormed edit selected. I guess the selection tool assumes the points are existing at the actual undeformed coordinates rather than the deformed :visual” coordinates.
    Which is odd becouse things like the pull, smear, smooth brush do infact work great in deformed mode but the selection tool doesn’t
    Or does it???
    TAK
  • Brian Jones
    March 2, 2006 at 3:15 am
    [Tak West] “What I want to be able to do is “Select” points or polygons while an object is being deformed. And then use the move tool or scale tool.”
    It’s working for me, at least it is in a quick test, with a capsule and the bend deformer… what deformer are you using?
  • Glenn Takakjian
    March 2, 2006 at 7:22 am
    I tried a couple of converted primitives and they all worked… except for a cube!!
    Try a cube and let me know if it works
    TAK
  • Brian Jones
    March 3, 2006 at 2:32 am
    works fine…
  • Glenn Takakjian
    March 3, 2006 at 2:44 am
    Can I send you a file? Its making me nuts
  • Brian Jones
    March 4, 2006 at 2:40 am
    sure, can you post it?
  • Glenn Takakjian
    March 4, 2006 at 3:37 am
    At the moment I have no place to post… That may change shortly
  • Brian Jones
    March 4, 2006 at 5:33 pm
    just email to bdjonesca@yahoo.com I can afford to lose that one if the bots get it… 🙂
    -Brian
  • Glenn Takakjian
    March 4, 2006 at 8:40 pm
    There must be a Karmic block in my Chakra. The answer to this problem is obviously to remain unknowable to me.
    The e-mail address you listed is returning failure notices to me
    DOH!!
    TAK
