Activity › Forums › Web Design (WordPress, Joomla, etc.) › podcast cgi – advice if you can
  • podcast cgi – advice if you can
    Posted by Mark Cookman on June 29, 2009 at 5:30 pm
    Where should I find or create the #{CGI_CONF_FILE} mentioned below ? …when Podcast producer fails my http error log reports:
    Fri Jun 26 19:27:31 2009 error https://client 10.23.1.172 /usr/share/podcastproducer/cgi-bin/pcastupload.cgi:36:in `read_config': CGI Configuration file does not exist (CGIException)
    Fri Jun 26 19:27:31 2009 error https://client 10.23.1.172 tfrom /usr/share/podcastproducer/cgi-bin/pcastupload.cgi:30:in `initialize'
    Fri Jun 26 19:27:31 2009 error https://client 10.23.1.172 tfrom /usr/share/podcastproducer/cgi-bin/pcastupload.cgi:275:in `new'
    Fri Jun 26 19:27:31 2009 error https://client 10.23.1.172 Premature end of script headers: pcastupload.cgi
    If I look at the file /usr/share/podcastproducer/cgi-bin/pcastupload.cg then line 30 reads as follows :
    class UploadCGI
    def initialize
    @config = read_config
    end
    def read_config
    if (!File.exist?(CGI_CONF_FILE))
    ASLLogger.error "#{CGI_CONF_FILE} does not exist"
    raise CGIException.new, "CGI Configuration file does not exist"
    end
    if (!File.readable?(CGI_CONF_FILE))
    ASLLogger.error "#{CGI_CONF_FILE} is not readable"
    raise CGIException.new, "CGI Configuration file is not readable"
    end
    # We need to read from our special config file for the location of the shared filesystem
    @config = {}
    File.open(CGI_CONF_FILE, "r") do |file|
    # Read all the key=value pairs out of the CGI config file into @config
    lines = file.readlines
    lines.each do |line|
    key, value = line.chomp.split("=")
    if (key && value)
    @configkey = value
    end
    end
    end
    Mark Cookman replied 17 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
