Activity Forums Blackmagic Design Pocket Ultrascope and Express34 USB 3.0
  • Pocket Ultrascope and Express34 USB 3.0
    Posted by Marc Colemont on August 11, 2010 at 1:57 am
    Did anyone tried to connect the Pocket Ultrascope with these new Express34 cards on a Macbook Pro running Windows7 bootcamp (as Mac OSX does not support USB 3.0 express43) yet?
    I won’t need 3G, mostly 720P or 1080i viewing.
    Danny Hays replied 16 years, 1 month ago 3 Members · 3 Replies
  • Kristian Lam
    August 12, 2010 at 1:37 am
    Hi Marc,
    It’s not going to work because the ExpressCard 1.0 interface (2.5 Gb/s)does not provide enough bandwidth requested by the Pocket UltraScope.
    regards
    Kristian Lam
    Blackmagic Design
  • Marc Colemont
    August 12, 2010 at 6:41 am
    Ok thanks… bummer actually.
    Does it completely not work, or does it give dropped frames in the software when using it?
    Also when you connect non-3G sources like SD or 720P?
    Then the bandwidth should be fine. As my MXO2 does transfer 1,45GHz 720P and 1080i sources through the Expresscard34.
    Thanks for your help.
  • Danny Hays
    August 12, 2010 at 9:01 pm
    I was wondering the same about the Shuttle. My laptop PCI express slot doesn’t have the bandwidth to support the Shuttle, so it won’t let me install the software, even if I only wanted to use the lower bandwidth settings, SD or MJpeg, so most likely your in the same boat. I had to build an I7 with an X58 chipset motherboard with
    USB 3.
