Activity › Forums › Apple Final Cut Pro Legacy › PNG Transparency fine in RT, but renders like crap.
Posted by Cory Caplan on June 23, 2009 at 1:09 amI have some absurdly small disclaim text which is using a PNG, and looks just fine in RT, but rendered in Prores422 (both HQ and non) looks like the edges go to 1-bit alpha. Or at least not “right”
Any ideas?
Cory
Cory Caplan replied 17 years, 2 months ago 6 Members · 12 Replies -
Steve Eisen
June 23, 2009 at 1:51 amCould be the font. Where are you viewing this?
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Cory Caplan
June 23, 2009 at 4:06 amIt’s arial narrow, but that’s not so much a concern, it’s a rasterized “graphic” …does the font matter so much? I’m having a problem with a layer above it too, an animated qt.
I just don’t understand how it’s processing the alpha differently in RT vs render SO DRASTICALLY. Might be a new QT bug or something, don’t know if anybody else is experiencing something similar.
https://www.spacecadet.com/video/gkphr/renderproblem.jpg
Tracks are like this:
>V4 – Disclaimer PNG
>V3 – QT Animation Codec w/ Alpha
>V2 – Transparent PNG blue letterbox
>V1 – Video/Solid PNGTime to panic.
Tom Wolsky
June 23, 2009 at 4:14 amWhat format is this? Are you looking at a rendered output in playback on a video monitor? You can’t assess an interlaced format on a computer monitor, especially not with text that crappy.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Cory Caplan
June 23, 2009 at 4:43 amYes, the results are the same on my Aja LHE. As a matter of fact, it plays perfectly fine on a monitor unrendered, and then, once rendered looks on the monitor like it does on the screen.
Now I’m getting nervous…
Cory Caplan
June 23, 2009 at 11:25 amI only have this problem if I render in Prores422. (No difference between HQ ON/OFF)
This must be a recent development or somebody surely would have noticed this, yes? Kind of a big deal..
If Avid DV50 can do it, surely Prores can?
Steve Eisen
June 23, 2009 at 1:55 pmBuild your comp in Motion or Live Type.
Steve Eisen
Board of Directors
Rafael Amador
June 23, 2009 at 2:40 pmHi Cory,
Have a look in the Browser about the Field Order.
I don’t know why many times they show up as Interlaced spoiling the rendering.
rafael -
Rafael Amador
June 23, 2009 at 2:41 pm -
Cory Caplan
June 23, 2009 at 2:56 pmThanks for the suggestions.
the PNG isn’t interlaced, and clearly isn’t the problem, as I can change the codec, and it works fine.
As for the recommendation to do it in Motion on AE, yeah, I had to move a lot of the project to AE, but I still need to do the name/web super and the disclaim in FCP because of the 80 or so different versions I have to generate. Luckily (?) I can do the workaround with animation codec or whatever, if I don’t find a fix.
This is clearly a Prores glitch..
Chris Borjis
June 23, 2009 at 4:08 pm[Cory Caplan] “the PNG isn’t interlaced, and clearly isn’t the problem, as I can change the codec, and it works fine.”
Cory, that could actually very well be the problem.
being interlaced doesn’t matter. changing the codec doesn’t matter.
in some instances not setting a field order of either a sequence or an item
can cause this very problem your having.
