Activity Forums Avid Media Composer PNG into avid
  • PNG into avid
    Posted by Derik Thadd on July 2, 2007 at 7:56 pm
    I an trying to import a PNG w/Alpha into Avid Media Composer and once inported,
    the file is all messed up. does avid just not work well with PNG files?
    David Braswell replied 19 years ago 3 Members · 2 Replies
  • Fred Williams
    July 3, 2007 at 1:44 pm
    Yes Avid works with PNG. I import them daily. Check your import settings.
  • David Braswell
    July 4, 2007 at 3:46 pm
    Could you define “all messed up”? I’m guessing you forgot to check “invert existing alpha” when you imported the files. Otherwise, you may have interpreted pixel/aspect ratio incorrectly. PNGs are a darling to work with in Avid. 🙂
