Activity › Forums › Adobe Premiere Pro › PNG files won’t show in exported material
  • PNG files won’t show in exported material
    Posted by Costin Becheanu on December 23, 2018 at 11:18 pm
    CC 2014
    I have several stacked png files throughout my project. They are just black solids. In premiere they have multiple opacity masks.
    Specifically when I check “use maximum render quality”… the final video will come out missing all the pngs.
    If I export without it checked, everything exports fine.
    Is this to be expected?
    Todd Perchert replied 7 years, 8 months ago 3 Members · 3 Replies
  • Ann Bens
    December 26, 2018 at 7:17 pm
    You dont need max render quality if you have a dedicated gpu card.
    Adobe Certified Expert Premiere Pro CS2/CS6/CC
    Adobe Community Professional
  • Costin Becheanu
    December 27, 2018 at 10:31 am
    Thanks. In the mean time I figured out how dumb I am. Max render was sort of cleaning up my work. What I did was I set my pngs opacity while having filmconvert on. Not being able to see in my previews nor in my non-max render exports the fact that the opacity work on its own for the pngs super low … therefore I couldn’t see the pngs anymore. So I went back, turned filmconvert off, readjusted opacity for pngs, then turned on filmconvert ( saw very dark previews this time) but when exported with max render, it was fine.
  • Todd Perchert
    December 31, 2018 at 4:37 pm
    Unless you are scaling to a different frame size, I’d just leave Max Quality Render off. I’ve gotten mixed results with it on even when scaling. So I never use it.
    TC
