Activity Forums Adobe After Effects PNG files looks like panned and corrupted when i render…
  • PNG files looks like panned and corrupted when i render…
    Posted by Pepe Sierra on September 22, 2008 at 11:10 am
    Hi to all…
    I have a project to render and looks fine when preview, but when i render, PNG files looks like panned and corrupted. Someone knows by?
    Sorry for my english…
    Un saludo
    Pepe
    Pepe Sierra replied 17 years, 11 months ago 3 Members · 3 Replies
  • Mark
    September 22, 2008 at 11:37 am
    Sounds like there is something wrong in either your render settings or output module settings…I would go through them carefully and make sure things like full quality etc are selected. Also, where are you viewing the rendered PNG files ??? Maybe you are importing them into another app and using the wrong import settings…just a thought
    Mark
    Mark Harvey
    Senior Editor
    Le R
  • Chris Wright
    September 22, 2008 at 5:58 pm
    “PNG files looks like panned and corrupted”****
    you mean like not all the way rendered? Yes, that is because most likely you have a multiple core system with render frames simultaneously on. PNG’s don’t support that feature. If you want it, go with Targas(TGA) instead at 32bit/pixel RLE lossless.
    I actually use JPEG2000 image sequence, which is the movie standard. It uses wavelet compression which is lossless and is 4 times smaller than animation.(note: image seq mode you have to get separately.)
  • Pepe Sierra
    September 23, 2008 at 8:54 am
    Thank you very much!!! You´re right Mr. Wright…PNG output isn´t compatible with multiprocessing (render multiple frames simultaneously)
    Un saludo
    Pepe
