Activity › Forums › Adobe Premiere Pro › PNG file won’t render after being scaled down
  • Tero Ahlfors
    February 3, 2017 at 10:01 am
    What are you exporting with what specs? What’s the resolution of the PNG? What are your sequence settings?
  • Rory Appleton
    February 3, 2017 at 10:18 am
    Thanks for your response!
    see seq settings screen shot,
    Resolution of PNG: 9933 x 7016
    trying to export to: DNxHD 185x 1080i 50 –
    All renders fine except for the PNG and only have a problem after I mess with scaling.
  • Rory Appleton
    February 3, 2017 at 10:23 am
    <a href='https://images.creativecow.net/317716/seqsettings.jpg'><img src='https://i1.creativecow.net/u/317716/seqsettings.jpg' border='0' /></a>
    here’s the screengrab:
  • Tero Ahlfors
    February 3, 2017 at 11:08 am
    [Rory Appleton] “Resolution of PNG: 9933 x 7016”
    Would it be possible to save this file in a lower resolution and use that?
  • Jon Doughtie
    February 6, 2017 at 4:04 pm
    That would be the first thing I’d do – pull it into Photoshop and reduce the resolution, save under a different file name to preserve the original.
    If you aren’t doing any moves on it, take it down to the dimensions that will maintain it full screen. Good chance it resolves the problem.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Peter Garaway
    February 6, 2017 at 11:05 pm
    Hi Rory,
    This should be fixed in Premiere version 11.0.2. You may also try switching the renderer to OpenCL if available.
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
