Activity › Forums › Apple Final Cut Pro Legacy › PNG captions taking long render time
  • PNG captions taking long render time
    Posted by Bob Flood on May 21, 2009 at 2:47 pm
    Helllooo!
    I received a series of captions from a captioning company as PNG files, and when i put them in my sequence they take an awfully long time to render…a lot longer than tiffs or tgas. like 4 to 5 mins for 3 titles over 30 seconds, and no motion effects except static reposition. also when i first play the section after rendering, it drops frames.
    my timeline is DVCPROHD 720p 29.97 and the PNGs are 1280 x 720.
    they appear to have no background and no alpha channel, and yet they key with a 3 pixel stroke around each charachter, so there must be an embedded “key cutter” in the file. If I convert them to tiffs, i have to create an alpha for each one as there is no alpha channel in the PNG.
    Does anyone know how these PNG’s are keying? Is the Non-alpha “key cutter” the reason it takes so long to render?
    BTW, i have cut them all in, and took a couple o coffe breaks during the render time, so its not holding me up, but i would like to know for future
    thanx to you all
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
    Arnie Schlissel replied 17 years, 4 months ago 2 Members · 3 Replies
  • Arnie Schlissel
    May 22, 2009 at 5:01 am
    png files support transparency without an alpha, just like psd. I think that layered tiff files may support transparency, too, but I haven’t tired it out.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Bob Flood
    May 29, 2009 at 2:07 pm
    hey arnie
    thanx for the reply! sorry to take so long to respond, work and all (go figger!)
    do you know why it would take so long to render these png’s as just static titles?
    Bob Flood
  • Arnie Schlissel
    May 30, 2009 at 2:04 am
    [Bob Flood] “thanx for the reply! sorry to take so long to respond, work and all (go figger!)”
    I’m sure you had to wait for your .png files to finish rendering!
    I haven’t the slightest idea why the .png files take longer to render. I wonder if there’s a way to run a batch action in Photoshop to add an alpha and convert to .tif?
    Arnie
