Activity › Forums › Sony Cameras › PMW F3 + S-Log
  • Michael Palmer
    April 28, 2011 at 7:23 pm
    The S-Log feature will be available with the dual link firmware option. I believe it works with single link 4:2:2 also and it will require a 10 bit recorder to take advantage of S-Log.
    Good Luck
    Michael Palmer
  • Jeremy Garchow
    April 28, 2011 at 7:26 pm
    [Michael Palmer] “I believe it works with single link 4:2:2 also and it will require a 10 bit recorder to take advantage of S-Log.”
    10 bit 4:2:2 is fine and dandy. Thanks for the info. Are you sure about this, though? 🙂
    Are you saying the S-Log and Dual Link options are bundled together, but can operate exclusively?
    No S-Log available on SXS recording (just curious)?
    Thanks, Michael.
    Jeremy
  • Michael Palmer
    April 28, 2011 at 7:33 pm
    “Are you saying the S-Log and Dual Link options are bundled together, but can operate exclusively?”
    Yes
    8 bit won’t capture enough data so no SxS for S-log
    Good Luck
    Michael Palmer
  • Jeremy Garchow
    April 28, 2011 at 7:38 pm
    [Michael Palmer] “8 bit won’t capture enough data so no SxS for S-log”
    Well, it’s a gamma curve. I understand why this wouldn’t be advisable in XDcam, but just wondering if it was possible.
    Thanks much for the info, this is now more tangible.
    Jeremy
  • Michael Palmer
    April 28, 2011 at 8:01 pm
    I just took delivery of my F3 and I can’t wait for the upgraded firmware, and my friends from Convergent Design are working hard to make the Gemini 4:4:4 the best digital recording solution for the F3. S-Log will be a great new adventure.
    Good Luck
    Michael Palmer
