PMW-EX1 steadyshot and vignette in the far end of the lens related problem
Hello…
This is my first post to this great forum but unfortunately I have to report a problem related to EX1 and steadyshot function.
Yesterday while I was fooling around with my new EX1 camera i’ve noticed a weird vignette issue in the tele position of the lens and a few mm to the wide direction. It was a very weird vignette because it was moving while i was making some quick shocking moves to the right or left direction. Further “investigation” of the issue pin-point the steadyshot function of the camera.
This vignette effect was disappearing when the steadyshot function was turned off.Has anyone else can confirm that problem?
Here is a video in divx format showing that effect.
https://rapidshare.com/files/97961412/vignette.and.steadyshot.avi.html
At first the steadyshot function is turned on until I pass my hand front of the lens. After that I’m switching it off for a while and then again off and on a few times just to show the effect.
Thanks in advance
