Activity Forums Sony Cameras PMW 350 Subclip Errors / Inconsistencies
  • PMW 350 Subclip Errors / Inconsistencies
    Posted by Will Torbett on September 29, 2011 at 11:05 pm
    The issue: For some reason, in two random instances, the camera is not grouping its subclips as it does by default.
    Normally, every twelve and a half minutes (or four GB) the camera splits a take into subclips, which by the time we ingest the footage is one long clip (as it was shot).
    Strangely, we are seeing in a few instances the footage showing up as separate clips instead. (01, 02, 03..) with no way to join them in XDCAM software. See highlighted clips below.
    But it’s sporadic – grouped properly in the morning, unnaturally split later, fixed again in the evening. I checked with the director/camera ops, and they didn’t know anything about settings changing on the camera itself (and there’s not exactly a big external toggle to bump into).
    Any thoughts/suggestions? I can only assume it’s a fluke, but how can we fix this, and what should we be on the lookout for while shooting?
    Will Torbett replied 14 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
