Activity Forums Sony Cameras PMW 200 HDMI Out to Field Monitor Issue
  • PMW 200 HDMI Out to Field Monitor Issue
    Posted by Chris Gomersall on August 30, 2017 at 9:14 pm
    Attached a VX7i Field Monitor to my PMW 200 with an HDMI cable and I get nothing. I have set in the menu to output video to the HDMI port yet I get nothing. The HDMI is routed to Video IN on the field monitor and source is set to HDMI port. Might be the HDMI cable but thought I would ask here in case I’m overlooking something goofy. I inherited this camera at my new gig and the online manual is less than detailed in this regard.
    Thanks in advance for any help,
    Chris G
    Kind regards,
    Chris Gomersall
    go*************@***il.com
    817-944-4124
    http://www.vimeo.com/channels/texasvideopro
    Bill Griffin replied 8 years, 11 months ago 3 Members · 3 Replies
  • Mark Thompson
    August 31, 2017 at 1:35 pm
    I use a D7W monitor, not quite the same as yours.
    Usually I connect using the SDI connection but I tried the HDMI connection and it works just fine.
    Your monitor will have an input button, probably, and so you have to select between an SDI or HDMI source. You could have he wrong source setting.
    On the PWW 200 the default setting on the Video menu: SDI/HDMI/
    i.LINK I/O Select Selecting input/output signals for the connectors
    should be
    HD SDI & HD HDMI
    That is the default when you are using UDF HD mode. Unless you are using SD mode it is difficult to turn the HDMI off [but you can do it if you try].
    Good luck
  • Chris Gomersall
    August 31, 2017 at 3:38 pm
    Bill Griffin, a local cameraman, called me directly and suggested the same thing. The iLink was turned off but he also wisely suggested a system reset. THAT worked! Field monitor is pulling a great signal from the PMW 200 now. Thanks, Bill!
    Kind regards,
    Chris Gomersall
    gomersall.chris@gmail.com
    817-944-4124
  • Bill Griffin
    September 1, 2017 at 2:41 am
    Hello…
    Your very welcome……if you need anything I do sound work and I do have my EX-3…
    https://www.dallascamguy.com
    Bill Griffin
    HD Cameraman
    972-475-6870
    http://www.dallascamguy.com
    Dallas, Texas USA
