  • Ron Lindeboom
    February 26, 2009 at 6:18 pm
    We have given users the ability to edit posts up to the time that they are replied to and then they “lock.”
    Has someone replied to the post?
    If they haven’t, you will find a link that says “Edit Your Post” below the links to view posts, add a new post, search posts, etc., in the grayish bar located towards the top inside your post.
    If a post has been replied to, we will edit things manually sometimes depending on the situation.
    Best regards,
    Ron Lindeboom
    Creativity is a type of learning process where the teacher and pupil are located in the same individual.
