Activity Forums DaVinci Resolve pluraleyes files no sound in resolve
  • pluraleyes files no sound in resolve
    Posted by Martin Halm on November 30, 2012 at 10:37 pm
    hi there,
    i wanted to test pluraleyes 3 today for syncing canon 5D MkII H264 files with sound being recorded external without TC. syncing the files in pluraleyes went pretty smooth. and much faster than the old version.
    i exported the resulting MOVs (including the new audio) to a bin. surprisingly resolve does not play audio of these files.
    in the media pool the movie icons show the audio sign and in the audio window you see tracks 1 and 2 highlighted. i guess this means, resolve “sees”, that the MOVs contain the two tracks of audio. but: no signal there – abolute silence
    playing back the same files in apple quicktime player: no problem, picture AND sound OK.
    when i add the original MOVs into the media pool everything is fine. resolve sees and plays the sound of the internally recorded audio.
    right now i can forget about my “perfect” workflow i intended to go:
    1 – autosync video/audio in pluraleys
    2 – import resulting synced MOVs in resolve
    3 – 1 light color correction and burnins in resolve
    4 – export to avid DNxHD 120 for offline
    5 – edit in media composer
    6 – export AAF to resolve
    7 – import AAF
    8 – link to synced MOVs
    9 – grade and finish in resolve
    anybody has an idea? maybe pluraleyes creates none-standard files??
    iMac 2.93 GHz Intel Core Duo
    Resolve Lite 9.03
    Avid MC 6
    Martin Halm replied 13 years, 9 months ago 2 Members · 2 Replies
  • Michael Phillips
    December 2, 2012 at 3:31 pm
    Strange that it doesn’t see/hear the sound after the sync process. Perhaps in the interim, change the steps around a little:
    Grade first, create QuickTime wrapped DNxHD (not MXF wrapped)
    Sync in Pluraleyes
    Either fast import or AMA consolidate which both should be just the time it takes to do a copy.
    Michael
  • Martin Halm
    December 2, 2012 at 6:28 pm
    hey michael,
    i just got answer today from RED GIANT support. they are aware of the problem and will see into it.
    thanks for your tip – this might work.
    martin
    Resolve Lite 9.03
    Avid MC 6
