Activity Forums Adobe After Effects Expressions Plugins with floating licenses disables calling functions in nested scripts?
  • Plugins with floating licenses disables calling functions in nested scripts?
    Posted by Martin Bollerup on December 11, 2012 at 1:11 pm
    Hello
    This morning I got the Sapphire plugin installed and suddenly all my functions in my nested scripts were undefined. When copied to the main script everything worked fine…
    My question is:
    Is there a way around this or is it some kind of “firewall” build into After Effects? It happens on ALL projects – even though I’m not using the Sapphire plugin.
    I haven’t got the chance to test if the nested scripts works with a valid license because we haven’t got enough for all designers and developers. And this is the way things work around here so a workaround would be greatly appreciated.
    Martin
    /* nestedScript.jsx */
    function testNestedFunction(str)
    alert("This is a nested function saying: " + str);
    /* mainScript.jsx */
    function loadExternalScript(path)
    // [1] Create file object for the file you want to run.
    var nested_file = new File(path);
    // [2] Open the file for reading.
    nested_file.open("r");
    // [3] Read the file and evaluate the results.
    eval(nested_file.read());
    // [4] Close the file. That's it!
    nested_file.close();
    loadExternalScript("some/path/to/nestedScript.jsx");
    testNestedFunction("I'm your function!");
    Martin Bollerup replied 13 years, 8 months ago 3 Members · 4 Replies
  • Dan Ebberts
    December 11, 2012 at 4:17 pm
    I don’t have any way to test it (I don’t have Sapphire), but it sounds like a possible path or permissions issue. Did anything else change?
    Dan
  • Martin Bollerup
    December 11, 2012 at 4:31 pm
    No nothing else changed… But it seems like calling external functions is completely cut off.
    I’ll get back to you if I find a workaround or an explanation.
    Martin
  • Gary Oberbrunner
    December 12, 2012 at 1:16 pm
    Hi Martin; I haven’t heard of this problem before. Please contact support@genarts.com. They should be able to help you out.
    — Gary
  • Martin Bollerup
    January 15, 2013 at 2:12 pm
    Okay so I found a way to make all nested scripts part of the same scope. All functions needs to be bound to the first loaded script – the main script. And the function for loading nested scripts should be placed in main.jsx and this function should always be used for loading scripts – if you want it to be part of the same scope.
    I haven’t compiled and testet the code here but it should work.
    cheers,
    Martin
    //main.jsx
    this.loadExternalScript = function(path) {
    loadExternalScript("nestedScript1.jsx");
    testAlert_1("called fom main.jsx")
    //nestedScript1.jsx
    loadExternalScript("nestedScript2.jsx");
    this.testAlert_1(str) = function(str) {
    alert("nested 1: " + str);
    testAlert_2("called from nested 1");
    //nestedScript2.jsx
    this.testAlert_2(str) = function(str) {
    alert("nested 2: " + str);
