Activity Forums Apple Final Cut Pro Plugins not previewing in FCPX trial 11.1 – Effects & Transitions only
  • Plugins not previewing in FCPX trial 11.1 – Effects & Transitions only
    Posted by Cleo Rayner on April 11, 2025 at 3:28 pm
    Hi everyone,
    I’m running Final Cut Pro X 11.1 (trial version, 90 days) on a Mac M2 Pro.
    I’ve installed a plugin bundle from fcpxfullaccess.com (“The Ultimate Bundle”) and manually copied the Effects into the correct Motion Templates folder (/Movies/Motion Templates.localized/Effects/).
    In FCPX, the Effects and Transitions categories from the new plugins are listed – I can see the names – but when I click on any of them, no preview appears on the right side. I also cannot apply them. It’s like they are empty.
    On the other hand:
    – Titles, Generators, and LUTs from the same bundle work perfectly
    – No error messages
    – Other (default) Apple effects are working fine
    Does anyone know if this could be related to:
    1. Trial version limitations?
    2. M2 Pro chip compatibility?
    3. Or a plugin structure issue (something missing from the template folders)?
    Any help or similar experience would be greatly appreciated!
    Thanks so much!
    Devrim Akteke replied 1 year, 3 months ago 2 Members · 1 Reply
  • Devrim Akteke
    April 11, 2025 at 5:20 pm
    Hi, It is hard to say what could be the problem. But first, did you contact them for support?
    They have 2 videos about this issue, I guess you watched those. It should be better to ask for support.
