Activity › Forums › Apple Final Cut Pro Legacy › Plugin to Emulate Handheld Footage???
Posted by Max Frank on February 1, 2011 at 9:35 pmHi there,
I have some locked off HD interview material that I’d like to appear
as if it were shot handheld.Is there a plugin for FCP [or Motion, at the worst] that will help
emulate a gentle floating, ‘breating’ camera. I’m not looking for anything extreme – just something subtle.Thanks,
Wayne
Matthew Bradshaw replied 15 years, 7 months ago 8 Members · 14 Replies -
Thomas Morter-laing
February 1, 2011 at 10:20 pmDo I sense a request for a magic plugin because of lack of prior planning? I’ve been told off on here for less….
Tom Morter-Laing
Freelance Editor
Certified Apple Product Proffessional, 2010
http://www.depictproductions.co.ukSony Z5, with Rode NTG2.
iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD. -
Max Frank
February 1, 2011 at 10:27 pmTom,
You score a 10 for snark and a zero for helpfulness.
Thanks for playing.
Wayne
David Roth weiss
February 1, 2011 at 10:35 pmOh goodie, maybe I’ll get some “helpfulness” points…
Scale the footage up about 15% Wayne, that’s necessary because your edges wil give away what comes next if you don’t.
Now, keyframe subtle random movements over time in the Motion tab on both the X and Y axis. It’ll take you a while to get it to look natural, but you find a rhythm you’ll find its pretty easy.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Richard Sanchez
February 1, 2011 at 10:44 pmI’d recommend doing this in After Effects. Drop your clip into the timeline and control click the position parameters. This will allow you to type an expression. You want to type wiggle(10,1) 10 is the amount of wiggle, 1 is the frequency. So, once a second it will wiggle by 10 pixels. (I might be backwards on that, but it’ll be easy to tell once you know the rule behind it) That’s how I’d do it. Less manual labor, and it’s smoother looking than in FCP.
Richard Sanchez
North Hollywood, CA“We are the facilitators of our own creative evolution.” – Bill Hicks
Matt Callac
February 1, 2011 at 10:54 pm[Richard Sanchez] “(I might be backwards on that”
Yes, you are backwards. first number is frequency. wiggle(1,10) would be every second wiggle 10 pixels.
and this is how I’d do it as well. Much faster, and much more organic result. You’ll still have to mess around with the numbers to get the exact look you’re wanting. Also you’ll need to scale your footage up a bit to hide edges, as david already mentioned.
-mattyc
Max Frank
February 1, 2011 at 10:55 pmFull marks for David & Richard, thanks.
Although AE is the right tool for this job, I think I’m going to have to do it Old School as per David’s suggestion.
My only hesitation was that I couldn’t find a way to Smooth the keyframes in the ‘Center’ settings [as you can with the Scale setting, hence wanting a plug-in.
But a short test actually provided some good results, so thanks for the suggestions gents.
Wayne
Matt Callac
February 1, 2011 at 11:04 pm[Wayne Marx] “My only hesitation was that I couldn’t find a way to Smooth the keyframes in the ‘Center’ settings [as you can with the Scale setting, hence wanting a plug-in.”
you do that in the canvas window. If you select the layer you are moving..click the keyframe you want to smooth..right click and select ease in/ ease out from the menu..then you’ll have handles to adjust your ease amount.
once you have keyframes you like you can always send to motion project. FCP keyframe easing isn’t the greatest. It works for some things…but for anything bordering on more than basic I’d port it to motion..then you can modify your keyframes on a graph view.
-mattyc
Matthew Bradshaw
February 1, 2011 at 11:11 pmCheck the Motion forum, Motion has an easy to use Random Behaviour that should do the trick.
Matt. -
Max Frank
February 1, 2011 at 11:17 pmMatt,
Thanks for reminding me about the Canvas settings.
And thanks to you, too, [other] Matt.
Wayne
