Activity Forums Sony Cameras Plug Output of EX-1 into a Computer Monitor
  • Plug Output of EX-1 into a Computer Monitor
    Posted by Wes Browning on July 20, 2010 at 1:56 am
    I have an EX-1 and would like to use a Computer LCD Monitor as an on-set monitor for the talent (ie. not for referencing). The monitor has HDMI, DVI-D, and VGA connections. What’s the best way to get the EX-1 hooked up to it with these options?
    Bill Kunitz replied 16 years, 1 month ago 3 Members · 2 Replies
  • Craig Seeman
    July 20, 2010 at 2:17 am
    https://www.blackmagic-design.com/products/miniconverters/
    SDI to HDMI miniconverter.
    It’s one of those moments you wish you had an EX1R
  • Bill Kunitz
    July 21, 2010 at 7:58 pm
    …or you could check to see if the monitor has a component video input (component – Y/Pb/Pr, not composite). You’ll get full HD straight from the camera. If it doesn’t have a component in, you can get a good sized HD set that does have component input for about the same money as a converter – ‘course then you won’t have the conveter for other uses.
