Activity Forums Apple Final Cut Pro Legacy Plug-ins won’t load.
  • Plug-ins won’t load.
    Posted by Tangier Clarke on September 7, 2005 at 6:21 pm
    mall dilema folks. I have a whole bunch of plugins that won’t load. I tried putting them into the FCP plugins folder in my personal user library as well as the top level library FCP plugins folder.
    FCP will not load any of them. Does anyone have suggestions?
    G5/Panther.9/FCP HD
    Chuck Reti replied 21 years ago 4 Members · 4 Replies
  • Walter Biscardi
    September 7, 2005 at 6:30 pm
    Are you simply trying to copy them over from somewhere else?
    You probably just need to re-install them.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Steve Eisen
    September 7, 2005 at 10:19 pm
    If you have Automatic Duck, put a Z in front of it and see if that solves your problem.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 2.45 TB External Stor
  • Tangier Clarke
    September 8, 2005 at 3:37 pm
    Yes, I have copied them from my own plugins folder to other FCP stations and they all work without installing them. Actually the installation process for all of them is simply to drag them to the correct plugins folder, however for just one machine, FCP will not load them.
    Tangier
  • Chuck Reti
    September 8, 2005 at 5:27 pm
    I had a set of copied-over Generators and effects plugs that would not show up in the application. I ended up (per advice read on this forum, I believe) doing a “Get Info” on each one, and making sure that permissions were set to “Read and Write.” Once that was done, they magically appeared.
    I have a related question, at least pertaining to FCP HD (4.5)-
    It appears that there are at least two locations where PlugIns can be located. One is in the customary /Library/Application Support/Final Cut Pro System Support folder, but there is also a “Plugins” folder in the FCP HD application bundle. Get Info, Show Package Contents, Contents, reveals a buried Plugins folder. I did try moving or copying a few from the former location to this one, and they showed up and worked normally. When the plugs are within the application bundle’s Plugins folder, they show up handily listed in a PlugIns pane in the Get Info window for the FCP app, which can be handy to inventory what’s available and installed.
    Chuck Reti
    Video Editor
    Detroit MI
