Activity Forums VEGAS Pro PLs help getting 5.1 on Timeloine
  • PLs help getting 5.1 on Timeloine
    Posted by Richard Diandrea ii on February 6, 2010 at 7:02 pm
    I am using a SONY HDR-SR1 AVCHD camera that has a 4 channel built in mic. For 5.1 I believe it derives the center from L & R. I have a Boom MIc in the HOT Shoe which actually creates the center cahnnel, then providing for 5 mics & discreet channels. I’m using Vegas 9c…
    I know when I edited a significant amount of my older video that I was able to get 5 channels onto the timeline. Now I all I get is 2 to show up on the timeline. I have searhed and not found an answer. I also have tried everything i can think of…..can someone PLEASE offer some suggestions to me??
    Thank you……
    Richard DiAndrea
    Mike Kujbida replied 16 years, 7 months ago 2 Members · 6 Replies
  • Mike Kujbida
    February 6, 2010 at 7:09 pm
    Make sure to set the audio tab in your project properties to 5.1 surround BEFORE you drop anything on your timeline.
  • Richard Diandrea ii
    February 6, 2010 at 7:14 pm
    Just tried that and I get the same results…just 2 trax.
    AAAAAHHHHHHH!
  • Mike Kujbida
    February 6, 2010 at 7:25 pm
    Just to confirm this.
    File – Properties – Audio – 5.1 Surround in the Master bus mode dropdown box.
    February 6, 2010 at 7:34 pm
    Yep. I wonder if my camera isn’t doing something wrong? I’ve looked at the camera and even got the intruction maual out…can’t find anything that appears to be wrong….
    February 6, 2010 at 8:04 pm
    As it turns out, the mic I have attached apparently is faulty. When it is attached it goes goes into stereo only recording. When it is not attached or even just NOT turned on, the 5.1 icon appears and it records in 5.1.
    Thx for your response. sorry to waist your time.
  • Mike Kujbida
    February 6, 2010 at 8:31 pm
    Richard, you’re definitely not wasting my time.
    I was curious as to why it wasn’t working and you found the answer.
    If someone else has the same problem someday, I’ll be able to offer a possible solution.
