Activity › Forums › Adobe After Effects › Plexus effect
  • Plexus effect
    Posted by Syed Iqbal on April 9, 2017 at 5:52 pm
    Hi folks,
    Tell me if there is any way of using an image of an object or person with transparency (PNG) as the base of Plexus plugin. Earlier I thought of projecting the said PNG on a plane inside Cinema 4d as material with Alpha channel and then export that plane object as OBJ file that I can use as my base object inside After Effects using Plexus plugin.
    I don’t know but I could not get it setup properly. So this was my long and indirect approach. Please guide with the right way of doing this.
    Syed
    Syed Iqbal replied 9 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
