Activity Forums Adobe After Effects Expressions Please. Script needed.
  • Please. Script needed.
    Posted by Aleksandrs Valters on January 12, 2010 at 11:13 am
    The situation…
    I have file that i was using before to load text and position into AE with expressions. But situation is changed and now i need Script (i can’t do this yet 🙁 )
    data.txt (contains information about data for layers in 3 compositions)
    __________________________________
    comp1_text_a=”1″
    comp1_text_b=”2″
    comp1_position_a=[11,22];
    comp1_opacity_a=[75];
    comp1_sub_composition_text=”Title”
    comp2_text_a=”1″
    comp2_text_b=”2″
    comp2_position_a=[11,22];
    comp2_opacity_a=[75];
    comp2_sub_composition_text=”Title”
    comp3_text_a=”1″
    comp3_text_b=”2″
    comp3_position_a=[11,22];
    comp3_opacity_a=[75];
    comp3_sub_composition_text=”Title”
    ____________________________________
    in AE i have TEMPLATE composition.
    Now i need script that will:
    1 – load data file
    2 – count number of needed compositions (3 in this situation)
    3 – take Template composition
    4 – duplicate Template composition with new name and change source text in text layers and position or opacity data on another layers with new data from file
    5 – p.s. very important to duplicate compositions inside as new, ‘cose they contain data that’s also must be changed from data.txt
    Full sample of script or partly help will be very useful, ‘cose i’m trying to do this 2 weeks =(
    p.s. Script needed for everyday use, some times data is up to 30 compositions.
    Lloyd Alvarez replied 16 years, 8 months ago 3 Members · 4 Replies
  • Sergei Sokolov
    January 12, 2010 at 11:29 am
    Shouldn’t this go to “Lower-Pay Jobs” forum? ; ) Can do the job.
    Kind regards,
    Serge!Sokolov
  • Aleksandrs Valters
    January 12, 2010 at 12:07 pm
    Yep.. why not 🙂 But who knows…
    Maybe some good man will give some help.
    At example what can help..
    How looks script (part of script) to change sourceText in Text Layer to text from script or from external file?
  • Sergei Sokolov
    January 12, 2010 at 12:13 pm
    Check out Adobe’s ExtendScript Toolkit + samples in /Applications/Adobe After Effects CS3/Scripts
    Also make sure you have AFx Scripting Guide handy:
    https://www.adobe.com/products/aftereffects/pdfs/aftereffectscs3_scripting_guide.pdf
    Kind regards,
    Serge!Sokolov
  • Lloyd Alvarez
    January 28, 2010 at 9:53 pm
    Hi Aleksandrs
    We have a script that does exactly that called CompsFromSpreadsheet. Go to aescripts.com and search for it.
    -Lloyd
    https://aescripts.com
