Activity Forums Adobe Premiere Pro Please play the test interlace video! Problem inGPU mode
  • Please play the test interlace video! Problem inGPU mode
    Posted by Masashi Sato on October 31, 2012 at 10:21 am
    Hi, I tested PremiereCS6 with Decklink SDI.
    Premiere can’t play correctly the interlace clip ,via Decklink ,in GPU mercury engine mode,on a interlace Sequence.
    Only single fieled is played to external monitor via Decklink.
    I upload the test video.
    https://dl.dropbox.com/u/5542662/interlace-test.mov
    (16MB, clip)
    Please,playback test.
    When you play the video via deckling to external monitor in GPU mercury engine mode,
    Are there 2 flashing square?
    When you play the video correctly, there are 2 flashing square.
    If you see no square or 2 white square, Premiere can’t playing the interlace video.
    if everyone can’t play the video correctory,in GPU demo, via Decklink or AJA,
    I think that PremiereCS6 software is not for Broadcast edit.
    Masashi Sato replied 13 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
