Activity › Forums › Blackmagic Design › Please modify the 4-Channel audio-capture in Premiere
  • Please modify the 4-Channel audio-capture in Premiere
    Posted by Oliver Petz on May 20, 2007 at 10:33 am
    Hello blackmagic-team,
    Please modify the 4 Channel audio-capture in premiere pro 2.0.
    the problem is: i am working with a sony digibeta-recorder and my daily business
    is to capture and play out 4 cannel audio to tape independly. why is it not possible to capture and playout SDI-channel 3/4 only from a digibeta whitout the “5.1-Surround-capture and playout-workaround “? it is not really easy to handle.
    every professional editing software which i use like avid media-composer, matrox axio and PPRO, and pinnacle liquid blue can do that!
    What i need is a “channel 3/4 only” capture-option in premiere and a mixer-setup-matrix in premiere which allows you to root every audio-track from a sequence independetly to SDI-Channel 1, 2, 3 and 4 without using the “5.1 Surround-workaround” .furthermore it would be nice if there is a audio-routing-matrix for the decklink spdif-audio-mointor.it is realy boring if you switch an audio-track via 5.1-Setup to SDI-channel 3/4 and you cant hear it anymore via SPDIF because the only option is to monitor the audiosignal 1/2 or 3/4
    (i think many people which are working with a sony digibeta-recorder want this too)
    A friend told me that these options and possibilities of independend- audio-Routing are integrated in Final Cut Pro/decklink-hardware . So why is it not possible to integrate these functions in Premiere Pro ?
    sorry for my horrible english 🙂
    Wolf replied 19 years, 4 months ago 2 Members · 1 Reply
  • Wolf
    May 20, 2007 at 11:50 am
    jepp, i have exact the same problem.
    With the new Digi-Bete DVW-970, many camera-crews are now
    using channel 3 and 4 for the atmo-sound.
    And the only way to caputre it in PPro is via 5.1
    And then, it isn
