Activity Forums Adobe Photoshop Please Help with Transparency Issue!
  • Please Help with Transparency Issue!
    Posted by Jbertain on October 3, 2007 at 4:38 am
    Tried searching heavily for an answer to this problem…so here it goes.
    I have an animation in ImageReady that’s been edited with transparency, ready to export. However, when I export and try to import into AE or even Final Cut, I lose alpha (becomes white).
    This is not for web, and the Flash file wont do (unless there’s no alternative I guess).
    I’m sure its an easy fix. Perhaps there is a certain format to export as? I’ve tried several different types; Animation, Uncompressed to name a few, but it becomes a variety of the same issue.
    If anyone can help me I’d greatly appreciate it!
    Thanks.
    Vincent Rosati replied 18 years, 11 months ago 3 Members · 3 Replies
  • Richard Harrington
    October 3, 2007 at 10:42 pm
    PNG files… but IR not a good solution for video work
  • Jbertain
    October 5, 2007 at 6:36 pm
    well then, what is the best solution for preparing transparent backgounds on video, ie transitions and such (forgive the illknowledge, I’m relatively novice)
    Any help would be greatly appreciated! Thanks
  • Vincent Rosati
    October 6, 2007 at 9:48 pm
    I agree with Richard. If you’re going to video, remove IR from your workflow and stick to AE, it’s like photoshop for video.
    It has a crazy learning curve, but the results are worth the effort. 🙂
    You can use Multiply, or other blending modes to knock-out an image. Plus, there are a bunch of other color keying options.
    AE has a pretty easy-to-use layer mask function, it’s vector, and you can keyframe it’s motion if necessary.
    You can prepare PSD files and bring ’em into AE.
    Just some thoughts…
