Activity Forums Blackmagic Design Please help with a xhg1
  • Please help with a xhg1
    Posted by Carlos Bermudez on August 12, 2009 at 2:07 am
    I need your help because it fails to capture the output via HDSDI the xhg1. Need someone please tell me the settings to be easy setup to be able to record directly to Apple Porres 1920 x 1080. I've really tried everything and can not. I record in 24F and in the resolution stating that.
    Thank you very much!
    Kristian Lam replied 17 years, 1 month ago 2 Members · 1 Reply
  • Kristian Lam
    August 13, 2009 at 12:14 am
    Hi Carlos,
    Which Blackmagic Design product are you capturing with?
    What version of drivers are you running now?
    I’m pretty sure the HD-SDI output of the camera is in 59.94. Have you tried a 59.94 ProRes easy setup?
    regards
    Kristian Lam
    Blackmagic Design
