Please help… Trying to output TV shows from FCP 4.5 (os10.4.3) to DSR 45 “edit to Tape” Please help.
First time using this configuration.
Trying to output to a DSR 45 from G4 (Dual1.0Gig)
I have a blackburst generator going into the deck and into FCP via a Blackmagic Decklink Extreme.
I am using FIREWIRE for audio, video and deck controlI have succesfully (as far as I can tell) blacked the tape using the FCP tape blacking dialogue from within the Edit To Tape window. I have blacked it with 30 seconds of preroll before my sequence’s first frame.
When I attempt an assemble edit by droping my sequence into the “assemble edit” box in the Edit to tape window everything seems to work fine until… the deck shuttles to the approximate timecode of my sequence start… shuttles back and forth a bit (as if looking for the exact input) and then gives up with the message:
” The end of tape has been encountered”
Also, while the deck struggles to find the in point on the tape… the timecode display intermittently shows another (seemingly unrelated) timecode.
I have no idea what I’m doing wrong. I’m sure it’s just one or two toggles on the deck. The time code section of the menu is set as follows:
TC PRESET: 09;57;30;00
UB preset: 00;00;00;00
TC/UB IN: TC&UB EXT
DV IN TC: INTERNAL
TC MAKE: PRESET
TC RUN: REC RUN
TC FORMAT: DF
JOG TC OUT: OFFI am outputing 4 tracks of audio via the firewire (I assume this is irrelevant)
IN conclusion… I just want to edit to tape (Assemble edit) a 24 minute TV show to DV cam.
If anybody has a suggestion or can see where I am screwing up please tell me. My time is running out as I scan the deck manual.
