Activity Forums Adobe Premiere Pro Please help. problem exporting
  • Please help. problem exporting
    Posted by Josh Goldener on August 7, 2009 at 6:53 pm
    When i edxport, media encoder opens, and then when I tell it to start cue, the status goes from waiting to yellow triangle.
    the error says something like “could not be found, check to see if it has been moved or deleted”
    Please help. I am being paid to edit this, and without exporting, my work is pointless
    Jon Barrie replied 17 years, 1 month ago 2 Members · 1 Reply
  • Jon Barrie
    August 7, 2009 at 10:48 pm
    From AME, Go to File>Add Premiere Pro Sequence and navigate to the project file, select it. Let it think for a bit as it is looking through the entire project to show you the available sequences. choose the correct sequence you want to export. It will be added to the timeline.
    If there is a problem finding the sequence or the timeline you are after then that means there is a problem with the actual project, like it’s not avaiable or the timeline was deleted in the project.
    If it works then maybe one of the folders was changed or moved and that’s why you got the error.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
