Activity › Forums › AJA Video Systems › Please help! – Kona 2 and Fottage shot @ 48fps
  • Please help! – Kona 2 and Fottage shot @ 48fps
    Posted by Baljit Deo on April 17, 2005 at 4:31 am
    Hello I have shot a music video at variuos speeds (24fps, 48fps and 60 fps)
    It seems the 24 and 60 fps footage is fine, meaning the 60fps was converted using the frame rate conveter and the audio sync works fine, however when I convert the 48fps footage it seems slower.
    Since when capturing 60fps using the 720p/60 capture pre-set and converting it down to 23.98 its ok, however capture the 48 at 720p/60 – the footage is slower i.e it should be 50% orignal speed and not 28.8%
    Can someone help here
    many Thanks
    bal
    Baljit Deo replied 21 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
