Activity › Forums › Apple Final Cut Pro Legacy › Please help. importing images from Photoshop into fcp, sizing
  • Please help. importing images from Photoshop into fcp, sizing
    Posted by Celeste on October 15, 2005 at 8:03 pm
    Greetings.
    FCP 4.5 HD
    Photoshop 7
    Mac OSX
    images scanned using Silverfast Ai software
    DPI 350 tiff files
    2000 pixels at longest length
    images will be zoomed into in fcp.
    In the past I have resized all my imges to import into a fcp project
    is it still essential to save psd still image as 720 X 534 Std.
    720 X 534, and thencange the image size to 720 X 480 and uncheck constrain porportions to prepare for fcp import or will FCP 4.5 automatically resize image?
    or is this a situation where the image will apprear squished in the canvas, but not on the monitor?
    If images have een saved as 640 X 480 or another setting, would it be possible to resave the initial psd file as the correct image file for correct viewing in fcp. is this 720 X 534?
    Hopefully you are able to follow this post. I am highly concerned about these images considering after they are scanned, they have been returned to their source.
    Any help would be appreciated.
    Thank you.
    Celeste replied 20 years, 11 months ago 6 Members · 16 Replies
  • 16 Replies
  • Bouncing Account needs new email address
    October 15, 2005 at 10:10 pm
    [celeste] “In the past I have resized all my imges to import into a fcp project
    720 X 534, and then change the image size to 720 X 480 and uncheck constrain porportions to prepare for fcp import or will FCP 4.5 automatically resize image?”
    You still do that with PS7 and FCP.
    Its not FCP that changed, but the “new” Photoshop “CS” that has the added “DV” setting.
    Its not “essential” to do this but it is the proper procedure.
    [celeste] “If images have been saved as 640 X 480 or another setting, would it be possible to re-save the initial psd file as the correct image file for correct viewing in fcp. is this 720 X 534?”
    Yes, but the quality might suffer a bit as the pixels will be slightly “enlarged” and “smoothed” by PS.
    I suggest that you EXPERIMENT with a few of these images in FCP.
    Try some images in FCP at their (unaltered) 640 x 480 (or whatever) size and then try the same images after you “up-size” a COPY of them in Photoshop.
    You’ll need to put each of them on the timeline, render them, and view them on an external video monitor to check which versions look best.
  • Tom Wolsky
    October 15, 2005 at 10:17 pm
    For DV material going to FCP start at 720×540 and resize to 720×480. For SD material start at 720×547 and resize to 720×486.
    October 16, 2005 at 12:48 am
    Well, there appears to be a bit of discrepancy regarding the DV “creation size”.
    Depending on who you read, its 720×534 or 720×540.
    https://www.kenstone.net/fcp_homepage/basic_ps.html
    https://www.geniusdv.com/photoshop%20final%20cut%20pro.php
    Does not compute, Will Robinson.
  • Bret Williams
    October 16, 2005 at 2:07 am
    Well it does compute. Very simple math. SD is 4:3. 4/3=1.3333 720/540=1.3333, 648/486=1.3333 and therefore working in SD (720×486) is 720×540.
    If you want to work in DV which is 720×480, you’re working with 6 less lines. The ratio is easy to figure out. Since 648/486=1.3333, then DV ratio in terms of square pixels would be six less lines, 648/480=1.35 and 720/534=1.3483, which is close enough.
    But I didn’t know there was any controversy. I thought everyone knew that DV was 1.35 aspect pixels, and that SD was 1.3333. Heck, it even says so right there in Photoshop when you create a new doc. SD 601 NTSC 720×540. Or Standard NTSC DV 720×534.
  • Celeste
    October 16, 2005 at 4:26 am
    Thanks for your input. So, to confirm: if the scans are being saved in photoshop 7.0 as
    720 X 534 std ntsc (a preset) this should be fine for fcp editing. I had done some tests, brining them into fcp and the image was squished or did not fully fill the canvas.
    October 16, 2005 at 6:06 pm
    [Bret Williams] ”
    But I didn’t know there was any controversy. I thought everyone knew that DV was 1.35 aspect pixels, and that SD was 1.3333. Heck, it even says so right there in Photoshop when you create a new doc. SD 601 NTSC 720×540. Or Standard NTSC DV 720×534.”
    Did you READ the two links I provided, (and Tom Wolsky’s post) which is WHY I consulted to the sources I listed.
    Here they are again:
    [Tom Wolsky] “For DV material going to FCP start at 720×540 and resize to 720×480. For SD material start at 720×547 and resize to 720×486.”
    So, there IS a discrepancy in reading knowledgeable sources.
  • Bret Williams
    October 17, 2005 at 5:00 am
    I don’t need to read the links. I can do basic math. And I’ve NEVER heard the specs Tom mentioned. They in fact, don’t add up. They’re incorrect.
  • Bret Williams
  • Celeste
    October 17, 2005 at 5:31 am
    I understand that the images need to be saved as 720 X 534 and then saved as 720 X 480. After additional research and speaking with an experienced editor he noted to me that even if images are left as saved as 720 X 534, these images *can* be adjusted in fcp to match correctly. Is he wrong?
  • Alexander Kallas
    October 17, 2005 at 6:33 am
    To avoid confusion and get your work done, upgrade to CS and use the video size presets,
    Worth the money to avoid errors and allow faster workflow.
    Cheers
    Alexander
