Activity Forums Maxon Cinema 4D Please help ! High quality bake objects!
  • Please help ! High quality bake objects!
    Posted by Nicu Vlasce on February 20, 2022 at 1:08 am
    Hi
    friends! I have a situation for which I need a little help! I’m working
    on a virtual studio in Cinema 4D. This studio will be exported in
    collada format to be imported into a broadcast software (Aximmetry).
    Aximmetry works with light maps to simulate reflections and lights and
    that’s why I have to get these maps from Cinema 4D. As you can see in
    the attached file I have a wall with a lighted object. The light emitted
    by the object is scattered correctly in rendering, but when I want to
    get the texture (bake objects), it fails to retain the light information
    correctly and appear these errors marked in the second file! Can
    someone help me how to set Cinema 4D correctly to get a good quality
    texture! Many thanks for your time!Hi friends! I have a situation for which I need a little help! I’m working on a virtual studio in Cinema 4D. This studio will be exported in collada format to be imported into a broadcast software (Aximmetry). Aximmetry works with light maps to simulate reflections and lights and that’s why I have to get these maps from Cinema 4D. As you can see in the attached file I have a wall with a lighted object. The light emitted by the object is scattered correctly in rendering, but when I want to get the texture (bake objects), it fails to retain the light information correctly and appear these errors marked in the second file! Can someone help me how to set Cinema 4D correctly to get a good quality texture! Many thanks for your time!
    Nicu Vlasce replied 4 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
