Activity Forums Apple Final Cut Pro Legacy please help film student TONIGHT! can capture only 3-5 sec clips! why?
  • please help film student TONIGHT! can capture only 3-5 sec clips! why?
    Posted by Michael Freund on April 12, 2007 at 4:12 am
    the message that comes up says
    “capture encountered a problem reading the data on your source tape. this could be due to a problem with the tape. capture has been aborted and your clip has been saved.”
    with any tape i use, i tried ten different ones, with any camera i hook up, i tried seven different ones. come on, i can’t be the first guy this happens to? please help out! my final project is due tomorrow, i kid you not.
    thanks, people.
    desperate in pasadena
    Cade Muhlig replied 19 years, 5 months ago 8 Members · 7 Replies
  • 7 Replies
  • Lee Mceachern
    April 12, 2007 at 5:41 am
    I’m sorry, I do not know the answer to your question. I am pretty new to Final Cut and I’m learning, myself. But if I had run the tests you ran, I would conclude that you have eliminated source tape and source deck as a problem. I would concentrate on the computer. I don’t know much about the capture settings yet but perhaps that could be an issue. Also, want kind of drive are you capturing to? Have you captured to that disk successfully in the past. Can you plug in a different drive and try that? This sounds hardware-ish to me. Sorry I’m not better informed. I wish you good luck.
    Lee
  • Justin Luo
    April 12, 2007 at 6:14 am
    Not too sure about the details to your problem but here are a few suggestions that might be of help:
    1. Check if the deck or camera that using plays the tape fine on playback mode. (if you recorded on long play, then things will get a little complicated)
    2. Log and Capture – set capture device to non-controlable and capture settings to that which is revelant to the tape format.
    3. press play on the deck and hit record now on FCP. capture the whole tape into your system.
    Hope that it helps. Btw, editing for tmr simply don’t work, regardless of how little or much you have to do.
    cheers!
  • 13 Create COW Profile Image
    13
    try trashing your preffs
  • James Carl
    April 12, 2007 at 6:16 am
    Did you check all your settings to make sure they match what you are capturing? Also did you try to toss the preferences?
    https://www.lafcpug.org/Tutorials/basic_trash_prefs5.html
  • Alec Gitelman
    April 12, 2007 at 5:44 pm
    yes, this is a very likely solution. make sure video capture settings match the setting of what you’re capturing.
  • Michael Hoffman
    April 13, 2007 at 2:01 am
    What version of FCP?
    What version of OSX?
    What camera model?
    What format video?
    What drive have you designated as your scratch?
    x
  • Cade Muhlig
    April 14, 2007 at 12:59 am
    make sure you dont have any other firewire devices plugged in. that was my prob when that happened
