Activity › Forums › Adobe Premiere Pro › Please help!!! Can not find progressive preset
  • Please help!!! Can not find progressive preset
    Posted by Tclark on May 24, 2006 at 6:05 pm
    Hello,
    Can someone tell me how to set up a project with a DV NTSC 29.97 PROGRESSIVE timeline? There is no preset and if I choose a DV NTSC 29.97 preset It does NOT have the option to change the field order to none progressive like we used to be able to do it in 1.5. All it shows is either upper or lower.
    Thanks for your help! Very appreciated!!
    Marcus Van bavel replied 20 years, 4 months ago 5 Members · 18 Replies
  • 18 Replies
  • Steven L. gotz
    May 24, 2006 at 8:54 pm
    Presets are merely suggestions. Have you tried making a custom project using the Desktop option instead of DV NTSC? As far as I know there is no progressive DV NTSC so there would be no need for a preset.
    If you are using a capture from a MiniDV camera, you should edit in an interlaced project and then export as prograssive. Or, deinterlace every clip on the timeline. If you are animating from other applications and not using video, use the Desktop method.
    Steven
    https://www.stevengotz.com
  • Tclark
    May 24, 2006 at 10:08 pm
    What does the Desktop Editing mode mean exactly? What does this option do exactly?
    How would one go about setting up a project for a camera that shoots 29.97 progressive video?
    Say for instance a Canon Camera with frame movie mode. I know that is not true progressive but it does not have fields in it. I would think that they would need a project setting of 29.97 that is progressive.
    Unless I am missing something.
    Thanks again for your help
  • Andre De clercq
    May 24, 2006 at 10:32 pm
    Still confused…Progressive DV images are indeed recorded and transported as interlaced fields. So APP behaves exactly the same way as with interlaced pictures. Field order may be not important but frame recognition IMHO is needed. If not, it can happen that consecutive field pairs comming from two different frames are being proceesed and if there is motion, all processed frames will show “mouseteeth”. So, my question is: does APP with progressive footage, recognise the fields which belong to the same frame?
  • Tclark
    May 24, 2006 at 10:43 pm
    Those are some of the things I am wondering about also. Great question!!
    Hopefully the desktop editing mode will solve the problem but I am still unclear to what exatly this editing mode means by “desktop”
  • Tclark
    May 24, 2006 at 10:49 pm
    Thanks Steven for your response.
    Which video rendering compressor would you use if you chose desktop mode?
    It will not give you the option of DV NTSC.
  • Steven L. gotz
    May 25, 2006 at 1:11 am
    It can’t give you DV NTSC because there is no such thing as DV NTSC progressive. Pick a codec, any codec.
    I believe you are making an incorrect assumption. I believe you should use a standard DV preset and edit that way. If you want to deinterlace everything, then do so. If it doesn’t need deinterlacing, then so be it. Export as progressive.
    Steven
  • Marcus Van bavel
    May 25, 2006 at 4:51 pm
    Steven tells me you are using DVFilm Maker.
    If you deinterlace to 30P you can edit in a regular NTSC
    (interlaced) timeline. The progressive and interlaced formats
    are compatible. However any effects or transitions that you
    apply will have interlacing in them, but that should not be a problem.
    Here are some more details which you can skip over if you don’t need them
    DVFilm Maker has several options. The simple deinterlace converts 60i to 30P
    or 50i to 25P. It can also convert 60i to 24p, or take 60i and convert it to
    60i with 24P plus 3:2 pulldown. It can also remove pulldown. In the case of
    30P, 25P or 24P the output is true progressive.
    By the way it is a misconception (not neccesarily yours) that a DV-NTSC
    codec encodes the fields separately and is somehow hardwired for interlaced
    material. Each macroblock can be encoded in either field mode or frame mode,
    but it’s decided anew on each macroblock depending on the content of the
    image and 30P is encoded equally well as 60i.
    The problem is that the NLE assumes DV-NTSC is 60i because there is no
    interlaced/progressive property in an AVI or Quicktime so the NLE often
    makes a guess at to which it is.
    You can edit 30P in a 60i timeline and there’s nothing wrong with that, it
    will preserve the 30P motion. However motion effects and transitions will
    have interlacing in them. That’s not a disaster as long as you’re not trying
    to make a transfer to film or a 24P DVD, and in that case 30P would not be
    appropriate anyway.
    If you edit 24P in a 60i timeline that is very bad, especially for a
    transfer to film or to make a 24P DVD. The user would need to use the
    DVX100A preset instead or desktop mode with custom settings, something where
    the frame rate is 23.976 and field dominance set to “None” or “Progressive”
    If you are editing Dv in desktop mode you have to install a VfW DV codec
    like the Matrox free DV codec, which is a good one. In desktop mode there
    is no firewire preview.
    https://www.matrox.com/video/support/ds/software/codec/home.cfm
    Steven asks why not edit 60i and then deinterlace? The reason is that
    the motion detector in DVFilm Maker is confused by cuts, and
    the result is 2 frames before and after the cut that are 1/2 resolution.
    Most people don’t notice it however. Also if you edit 60i and convert
    to 24P, you will sometimes get 1-frame dissolves on a hard cut. Again
    most people don’t notice. But the biggest drawback is that any motion
    effects such as slow motion will absolutely mess up a 60i to 24 conversion,
    so it’s best to do it before editing, if possible.
    Finally avoid both high shutter speeds and unmotivated pans when shooting 60i
    for conversion to 30P or 24P. It might look smooth at 60i but it
    might not at 30P or 24P. 1/60th or 1/50th sec is OK. Following action
    is OK.
  • Tclark
    May 25, 2006 at 5:43 pm
    Thanks Marcus!
    I really appreciate your time. That helps a lot.
    Great explanation!!
    Does this mean that anybody with a true 30p camera such as the canon xL2 should use a 60i preset when capturing 30p?
  • Marcus Van bavel
    May 25, 2006 at 6:00 pm
    [TClark] “Does this mean that anybody with a true 30p camera such as the canon xL2 should use a 60i preset when capturing 30p?”
    That’s correct
  • Andre De clercq
    May 25, 2006 at 6:24 pm
    Thanks Markus for the interesting information. You mentioned motion detection w.r.t. crossover artifacts, but does theis mean, in relation to my earlier question, that all NLE’s (not only DV Filmmaker)have motion detection for deciding which field belongs to which frame?
