Activity › Forums › Adobe Premiere Pro › Please help!!! Can not find progressive preset
  • Marcus Van bavel
    May 25, 2006 at 7:18 pm
    [andre] “Thanks Markus for the interesting information. You mentioned motion detection w.r.t. crossover artifacts, but does theis mean, in relation to my earlier question, that all NLE’s (not only DV Filmmaker)have motion detection for deciding which field belongs to which frame?”
    The built-in deinterlacers of Premiere, Vegas, etc. do not detect
    motion and also cut down the vertical resolution to about half.
    DVFilm Maker and other smart deinterlacers
    try to preserve full vertical resolution in areas of the screen
    where there is no motion.
  • Andre De clercq
    May 25, 2006 at 7:22 pm
    Thanks again Markus.
  • Steven L. gotz
    May 25, 2006 at 7:24 pm
    You have to love it when the guys who write software come on to the forum to answer questions. Thanks for all of the assistance.
    Steven
    https://www.stevengotz.com
  • Andre De clercq
    May 25, 2006 at 7:40 pm
    One last question Markus, if I may… When I capture clean progressive DV footage, it streams as interlaced, but doesn’t need to be de-interlaced in order to get progressive DV back I suppose. Does the NLE still throw away one field or does it detect the frame cadence in order to keep the fields belonging to the same frame, together? Or is the field order to be specified in this case.
  • Marcus Van bavel
    May 25, 2006 at 8:08 pm
    [andre] “One last question Markus, if I may… When I capture clean progressive DV footage, it streams as interlaced,
    No, all NLE’s store video on a frame-by-frame basis. Not field by field, not even if it’s interlaced.
    Deinterlacing progressive footage would not be good.
    Does the NLE still throw away one field or does it detect the frame cadence in order to keep the fields belonging to the same frame, together? Or is the field order to be specified in this case.”
    Doesn’t need to do anything because the 2 fields are always stored together.
  • Andre De clercq
    May 25, 2006 at 9:22 pm
    Thanks, but what I am confused about, is why the two fields stored together belong to the same frame in a continious upper, lower…field stream. Couldn’t it happen that the last field from frame n and the first field from frame n+1 are stored as couples?
  • Lyon Films
    May 25, 2006 at 11:35 pm
    Please, one more clarification for my sanity:
    1. Above you said if I shoot 30p in a Canon XL2 I should capture the footage in a 60i project? If so, will motion graphics imported from AE 7.0 still look OK? Also, will cross fades, disolves look OK?
    2. Someone on the DVI thread for a similar question also stated that for those of us shooting 30p in a Canon XL2 that we should be able to capture in the 30i lower fields project setting and then just make sure to export the final file for web, dvd, whatever, as “progressive”. Is this also true? Will motion graphics and transitions look OK?
    Thanks a ton as I really like to shoot in 30p and don’t want to be hamstrung.
  • Marcus Van bavel
    May 26, 2006 at 3:28 pm
    [Lyon Films] “1. Above you said if I shoot 30p in a Canon XL2 I should capture the footage in a 60i project? If so, will motion graphics imported from AE 7.0 still look OK? Also, will cross fades, disolves look OK?”
    [Lyon Films] “2. Someone on the DVI thread for a similar question also stated that for those of us shooting 30p in a Canon XL2 that we should be able to capture in the 30i lower fields project setting and then just make sure to export the final file for web, dvd, whatever, as “progressive”. Is this also true? Will motion graphics and transitions look OK?”
    I’m going to defer these questions to experts on Premiere.
    But except for the 30P setting in the camera, capture, project and export settings need to all agree to avoid unintentional effects.
Page 2 of 2
