Activity Forums Blackmagic Design PLEASE HELP AUDIO MONITORING TROUBLE
  • PLEASE HELP AUDIO MONITORING TROUBLE
    Posted by Oxyde on August 2, 2005 at 8:51 am
    hi,
    Im using a BM extreme and I have no sound when i’m capturing a tape using Final Cut Pro HD. After capture i could hear the sound from the timeline.
    We tried many different way, using the monitoring cable or the input cable to have audio without success.
    my computer ; G4 dual 1GHz , 1G ram, external 400G scsi
    buy the way when using decklink control we have the audio playback
    thanks a lot for yourhelp
    oxyde
    Luke Maslen replied 21 years, 1 month ago 2 Members · 1 Reply
  • Luke Maslen
    August 4, 2005 at 5:36 am
    This might be normal behavior if you are using the DeckLink card to generate a sync signal for the deck during capture. Please check the technical note How to sync a deck with a DeckLink card and specifically note the section named “Audio monitoring issues”. You will note further down in the technical note, it mentions the following.
    If you wish to monitor audio while capturing video from a deck, then you will need to use a blackburst generator to keep your video in sync. Disable the option “Black Video Output to Deck in Capture” and make sure you choose the “auto” or “external” reference setting on your deck.
    Regards,
    Luke Maslen
    Blackmagic Design
