Activity › Forums › Avid Media Composer › Please help
  • Please help
    Posted by Jack Entonces on July 27, 2007 at 10:34 pm
    I need to blur out someones face in a video.
    I’m using a resize/defocus on v1 .. on v2 i have same clip with animatte, draw a circle, and swap sources. I works just fine, only it’s not enough focus. How do I increase the intensity of the focus??
    THANK YOU ALL.
    Jack Entonces replied 19 years, 2 months ago 3 Members · 4 Replies
  • Michael Hancock
    July 28, 2007 at 1:44 am
    Why don’t you use the Blur effect instead of Resize? Then you can increase the blur to the point of total obscurity.
    Also, because you said you’re using Animatte, I assume you’re on an Adrenaline. If you are, depending on when you bought it/updated it, you should have Boris Continuum Complete. If you do, look for the Witness Protection plugin–it’ll do what you’re wanting and includes a motion tracker. That makes is much easier if the person is moving a lot.
    Michael.
  • Jack Entonces
    July 28, 2007 at 2:13 am
    I tried the blur effect.
    But I can’t figure out how to adjust the itensity of the blur.
    There are no sliders or buttons to play with in the blur effect editor.
    I don’t have Boris, sorry.
    thanks for the help
  • Erik Hermesman
    July 28, 2007 at 5:48 am
    you need to draw a mask with one of the shapes in the blur effect editor
  • Jack Entonces
    July 30, 2007 at 8:50 pm
    thanks!
