Activity › Forums › Adobe Premiere Pro › Please explain the relationship between sequence setting and output
  • Please explain the relationship between sequence setting and output
    Posted by Jim on June 9, 2012 at 12:08 pm
    I am looking for an explanation of the sequence setting and the output settings (Mac Quad core, 10.7.4 – CS6 Production Premium, PR) I am primarily working in AVC-I 100 and XDCam. I’ve found that I can drop in AVC-I into a Seq and it will set the Seq to that codec. Many times I’ll need to send the in-progress and final edits to my clients as an WMV (HD) video file. In FCP, I would export the self contained seq and use Episode to transcode to wmv. I’m having trouble understanding the best way to do this in PR (CS6). I’ve found that if I leave the Seq setting to the AVC-I, the render and the file output is a 50% quality mpeg-I. Is it best to set up a custom sequence w/ ProRes as the render codec? I’m having a hard time finding or getting an explanation of best practices for this type of operation. Any guidance would be appreciated.
    Jim replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
