Activity Forums Adobe Premiere Pro PLease commnts on my system config to run APProCS5 smoothly
  • PLease commnts on my system config to run APProCS5 smoothly
    Posted by Pushpanatha De silva on September 16, 2010 at 1:48 pm
    Hi
    Your (any) comments about following system is much appreciated. At present I am experiencing choppy video(draft quality video on monitor) and slowing the process on my Dell Dimension 8400(Pentium4/3.4GHz,2GB DDR2 RAM, 500GB HDD)when running Adobe PPro CS4. Video Camera used Sony PMW EX1 with Sony SXS memory cards.
    The system I am intend to buy is mainly to run the APPRo CS5 initially and later associated Adobe Master Collection programs( Eg. Fireworks, Dreamweaver, After Effects,Encore, Flash, Illustrator, Photoshop and Soundbooth).
    Dell Precision T7500 (Workstationchassis with 1100watts power supply (85%+ Efficiency Power Factor Correcting power supply)
    Intel Xeon E5630 2.53GHz, 12M Cache, 5.88GT/S QPI, Turbo, 4C
    Intel 5520 chipset
    Windows 7 Ultimate 64bit
    Dell back-up and Rcovery Manager for Windows 7
    24GB (6X4GB) DDR3 RDIMM Memory, 1333MHz, CC
    600 GB (15000rpm) SAS HDD Drive(for C:\)
    Two 600GB (15000rpm) SAS HDDs
    PRC6/i SAS/SATA Hardware RAID Card
    SAS Connector cable
    SATA Cable for 2nd Optical drive
    All SAS Drivs, RAID 5, 3 drive XtremeMusic
    Addiional Broadcom 5722 10/100/1000 Ethernet Networking LAN Solution
    Dell MS 111 USB Optical Mouse
    Dell QuietKey Keyboard
    3yr on-site warranty
    2 Monitors – 24″ – Dell MOdel G2410H Widescreen Flatpanel monitor s
    Integrated Intel SATA 3.0GB/S controller with support for RAID
    Integrated Broadcom 5761 Gigabit ethernet controller
    Integrated High Def Audio
    Slots: All full length except as noted
    1 PCI-e X16 Gen2 wired as X4
    2 PCI-e X16 Gen 2 slots wired as X8 (one is half length)
    2 PCI-e X16 Gen 2 Graphics slots
    1 PCI-X 64bit/100MHz slot with support for 3.3v or univrsal card
    1 PCI 32bit/33MHz 5v slot
    Standard I/O ports
    11 USB 2 (2 on front panel, 6 on back panel and 3 internal)
    IEE 1394a (One front, one rear)
    1 Serial
    1 Parallel
    2 PS/2
    1 RJ 45
    1 e-SATA port on back panel
    Stereo LINE-IN and Headphone LINE-OUT on back panel
    Microphone & Headphone connector on back panel
    Bays:
    4 Internal 3.5″ HDD Bays
    3 xternal 5.25″ optical bays, one of which can accommodate a fifth HDD
    1 xtrnal 3.5″ flex bay for floppy driv or Media crd Reader
    Total Weight 25Kg
    Your help on comments for above system are much appreciated.
    Thanks.
    Dexter Andrada replied 15 years, 11 months ago 2 Members · 1 Reply
  • Dexter Andrada
    September 17, 2010 at 10:04 am
    does it have USB 3.0? what about SATA 6/gb?
    You are purchasing a spanking new baby, these components will come into play when you commit to future upgrades.
    Also it would be helpful if you tell us on how you will use this. This might suffice for standalone workstations, but if you plan to connect this to a bigger network of computers with shared data your setup is not enough.
    Also your choice of monitors, should be able to preview pixel per pixel FULL HD.
    and at the same time do you intend to use AJA/Blackmagic cards with this?
    Hope these might help
